Workshop: Seasons Greetings with laser cutter 22.11.2016
Workshop on creating greetings with cardboard, plywood and if needed paint. Christmas is coming and it is time to create cards for all the greetings.
With laser cutter it is possible to cut cardboard (not corrugated) and plywood and engrave on both materials also. From cardboard it is possible to create a foldable greeting card and from plywood you can easily cut and engrave name tags for presents.
If interested bring your own laptop with vector drawing software. If you do not have a vector drawing software you can use Inkscape, https://inkscape.org/en/
Vectors are good for cutting or engraving, other paintings, bitmaps are good for engraving.
With nicely coloured cardboard the outcome should be great. Bring your own cardboard for best effect.
Members registration (0€): https://vaasa.hacklab.fi/
Non-members registration (10€) https://holvi.com/shop/
